FS: Pass A75, Jensen 4 pole capacitors, d3a, Denon Dl 103
Some random things that I don't see myself using anytime soon.
Jensen 10,000uf 63V four pole capacitors, $80 for the pair. These would cost you $60 each from parts connexion, and are excellent capacitors for a solid state power supply. Brand new, never soldered or used.
Denon DL-103. I have a two for sale, both are new and sealed. It's the cartridge I still use, but I already have a backup so I don't need these two. Also have a threaded aluminum mounting plate if you are interested in modding these and using them nude.Made in Japan. $140
Siemens D3a tubes. Have a whole sleeve, $10 each.
E.F. Johnson 7 pin ceramic tube sockets for 813s, possibly others? Was going to use these in a monster 813 amplifier project. These are very nice NOS tube sockets, which are MUCH better than the new sockets made in China. Ceramic, made in USA and heavy duty. $30 for the pair
Finally, a once working Pass A75 amplifier. Includes all components needed to work, although it is missing a XLR jack. No heat sinks are included, but the bottom and back panel are. Also includes an extra set of output boards. Dual toroids, a massive power supply, and a fine design that would sound great if restored to working order. $100
