Open Baffle Woofer for less.. Goldwood GW-1858
They aren't quite the same. One is a model 1858 and the other is 1850.
GW-1858:
Power handling: 220 watts RMS/310 watts max
* Voice coil diameter: 2.5"
* Le: .6 mH * Nominal impedance: 8.0 ohms
* Re: 5.26 ohms
* DC resistance: 6.2 ohms
* Frequency range: 30-2,000 Hz
* Magnet weight: 50 oz.
* Fs: 30 Hz
* SPL: 94.2 dB 2.83W/1m
* Vas: 18.50 cu. ft.
* Qms: 6.65
* Qes: 1.27
* Qts: 1.07
* Xmax:. 3.36 mm
* Net weight: 11-1/3 lbs.
GW-1850:
Power capacity: 150W/300W RMS/peak
Frequency response: 35 ~ 3,000 Hz
Nominal impedance: 8 Ω
Voice coil diameter: 3"
Sensitivity: 92 dB W/M
Fs: n/a Hz
Re: 6.4 Ω
Qms: n/a
Qes: n/a
Qts: n/a
Vas: n/a L
Mms: n/a g
BL: n/a
Xmax: 3.5 mm
Possibly. But perhaps the spec.s are off for one or both rep.s..
They are at least very similar, and should work reasonably well as a open baffle helper woofer in the context that Martin presented.
For a product with such a use, price is the major factor.. and I'd suspect that shipping costs would play a large roll in determining it's relative value.
