Soundstream XXX6500
I replaced the outputs in this amp. Also repaired some of the work done by someone else.
Amp powers up and relays kick on But no output.
I set my scope to 10us 20V/div I dont see a square wave on any of the outputs.
The amp is producing both + - rail and regulated voltages .
Wondering where i go from here?
I can't read all of the silkscreen on the powerbass I have here (similar to the SS amp you're working on). Here are the voltages from the driver board. Pin 1 is the input pin. Are yours similar?
It doesn't appear that your amp is producing rail voltage.
