I have a question, would be great if one of you clever people can answer it!
I am making a power supply for my new DAC! For the positive side (supplying +5/+15V) I have used a circuit that contains two lm317 regulators, the second one having using a lm329 voltage reference to reduce output noise.
My question is...can I use exactly the same circuit but with lm337 regulators for the -15v supply? Obviously the pin outs are different, I was more wondering if the lm329 will supply a negative voltage reference
Thanks in advance!
