How to Calculate volume of enclosure for a mid-range driver?
you can model this in Unibox, it is important because it affects the fall-off rate & this interacts with your crossover slope. However it's not critical unless the box is too small, when you start to get an LF hump.
For me, the internal damping & shape of the rear wall are just as important, to avoid internal reflections
