just wondering what other makes/models might drop in my little FE206E K-coupler without messing the baffle up with more holes. Nirvana Super 8 doesn't quite line up. (I'm front mounting)
FE207E (if still available) is the first that comes to mind - but how suitable for your application?
thanks - I should have phrased it - "Which non-Fostex have the same bolt pattern as FE206EN" - -I"ll probably put in a set of holes for my Nirvana Super 8 with a 45 degree rotation as FE206EN and Super 8 can share the same cutout. The cutout will accommodate W8-1772 from the rear but I'm not sure if I can work in the tight space (?)
