The 3W Hammond 125ASE output transformer
Will this be enough for my needs? I will be running a tweeter amp at 20mA for 1W out. This transformer is rated for 25mA and 3W. It is small (the core is only 3.5cm across), but that may be a good thing for the highs?? These aren't listed as a hi-fi unit but I don't mind a slight(?) top end roll-off. I thought about the larger units in the range but I thought that if a smaller unit might be better for treble, then why not get this one.
Hammond Mfg. - Universal - Single Ended - Tube Output Transformers - (125 Series)
