diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Could the Hawthorne Silver Iris be used in a enclosure (http://www.diyaudio.com/forums/full-range/172747-hawthorne-silver-iris-enclosure.html)
trondareo 29th August 2010 01:44 PM
Im just curious since there are several great coaxial speakers of old. For instance here:
Tannoy Speakers
Could one put them inbass reflex, horn enclosures,or or is there something in the Silver Iris construction the prohibits it?
Sterling Silver Iris OB 15" Coaxial Unit
Driver: 15-inch premium full-range coaxial driver with heavy gauge cast basket
Voice Coil: 2-inch
Power Handling: 150 watts RMS
Impedance: 8 Ohms
System Sensitivity: 97.3 dB/W/m
Qt: 0.70
XMax: 3.45mm
Fs: 35.9Hz
Magnet weight: 38ounces
Frequency range: 36Hz to 21kHz
Scottmoose 29th August 2010 03:21 PM
Technically yes, but with the relatively high Q & likely highish Vas it'd be a hell of a size (in terms of what most people consider large these days).
trondareo 29th August 2010 03:57 PM
Vas is 243,9 liters. which would be a box of for instance 50x70x70 cm
An aperiodic box might reduce the size a bit.
Here are all the data on the woofer section:
Woofer Specifications: • 15" full-range coaxial • Ideal for full-range, near field and monitoring applications in open baffle configuration • Heavy gauge pressed steel basket • 2" voice coil • Power handling: 150 watts RMS • Impedance: 8 Ohms • System Sensitivity: 95.8 dB 1w/1m • Le: 0.70 • Re: 5.77 Ohms • Qt: 0.91 • Vas: 243.9 liters • Xmax: 3.45mm • Fs: 41.8Hz • Magnet weight: 38ounces • Frequency range: 41.8-18k • Crossover network included • Cut out 13.75" • OD 15.25" 1" throat compression driver
sreten 29th August 2010 05:25 PM
Hi, its designed for open baffle, get something else for enclosures, rgds, sreten.
Scottmoose 29th August 2010 05:32 PM
Agreed.
That's the Silver Iris (which will need an even bigger box); the previous mentioned is the Sterling Silver Iris -note the different Qt for each. Note that the information supplied by Hawthorn is still incomplete.
Whatever way you look at it, it's going to be a big box.
GM 29th August 2010 09:24 PM
Quote:
Originally Posted by sreten (http://www.diyaudio.com/forums/full-range/172747-hawthorne-silver-iris-enclosure-post2287420.html#post2287420)
Hi, its designed for open baffle........
or TL. ;)
GM
trondareo 29th August 2010 09:43 PM
something like this?
tannoy9
GM 29th August 2010 11:00 PM
Same basic concept, i.e. damped folded pipe, though using different math.
GM
freddi 29th August 2010 11:21 PM
I have the standard Silver Iris and even small wings make them more claustrophobic sounding than a simple baffle - - go open baffle
http://img334.imageshack.us/img334/1566/siir1580nx0.jpg
theAnonymous1 29th August 2010 11:27 PM
Or buy something else and avoid regretting the purchase like I did. They sound like $%!#, regardless of box or baffle. :rolleyes:
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
