jboz J310, 12volts, question about Drain R
hi folks,
I have some J310 fets and want to use them for a jboz preamp. I'd like to run them on 12 volts. the j310 schema I found here has 24volt PS. the drain R is 2.2K. What would the best value of Drain R be for 12volt operation?
I tried 1k and it got loader :) Sources R is 560ohm...
thanks for any ideas,
Jeff
Thanks Mr. Pass,
I returned to the bench to toy with the circuit and found, to my horror,:eek:
I had used the jboz 2sk170 values for the J310 jboz...
that would explain the lack of function....I'll give it a go
with the correct values.
need to find a FET 101 book...
Jeff
