Hey guys...
I'm well under way on a amp build im working on currently and would like to slowly start gathering parts for the matching preamp.
starting with the output, i would like to have a selectable output configuration and want to incorporate a tube buffer or preamp stage on one output and a HDAM preamp on the other.
Theres a lot of EBAY kits and im not to tube "savy" so i figgure before i start burning money is always worth asking which one is worth it and what to look for
The reason why i want to incorporate a tube section is because i had to replace a board and a few items on a friends Dynaco PAS2 and after had it for a "burn in" for 2 weeks it sounded amazing to me, hence why i want to add one to my build
ALSO, balanced signal handling would be a BONUS !!!
Input needed on this kit to start off with...
drek - short and simple
if you need tube buffer - SLCF , Allen Wright , google
edit : for 143$ ........ better use much smaller money , and buy tube preamp cookbook and supercable cookbook from mentioned tube wakoo ...... that way you'll learn something ..... and never ever think again about buying audiophool fog on ebay
HDAM Module is basicly a high end audio opamp built from scratch with audiophile components.
HDAM Module Review by HeadFi.org
URL at the end of the Review was supposed to Point HERE
I must expose my ignorance. What is an HDAM? A full fledged tube line amp is so simple I often wonder why a buffer on something else has so much appeal.
It is from another reality, where conductivity is measured in RaMaOhms between Chakras.
Oddly I had to look up Chakra too.
hmmm...
i know its ebay again...
Jadis JP-200 JP200 Tube Pre Amplifier
but like i said earlier, i just want a PCB to make my life easy !!!
Given if i buy 2 boards can i use them to "buffer" balanced signals ??
And what benefits would a tube regulated supply give ???
Well, you could ... I just wonder why you'd need this horribly inefficient use of ECC83s doing double duty WITH 2000+x GAIN functioning as a buffer. Do you plan to put an attenuator somewhere that will quiet this thing down two thousand plus times ?
Oh and ECC83 doesn't make the best cathode follower out there, no matter what the schematic in your link says.
Basicly what I'm doing is building a Pre-amp to my own needs and wants....
Will include basic functions as Volume and Source Select - 4 XLR pairs, 2 TRS Pairs and 5 RCA Pairs with a "Monitor" Function. This will allow the use of a external processor or DSP and will have 1 pair of XLR's and TRS's . All unbalanced signals will be up-converted to Balanced Signal and handled internally in the balanced form. Output will be Balanced ( XLR and TRS ) and will also include a summing amp to have a pair of RCA's.
The Output Section will be selectable as either tube to HDAM modules with JFET's
Still debating if i want to incorporate a DSP board for time correction with a Graphic or Parametric EQ, but will have a Bypass for "source direct" mode.
For the Tube Section I'm looking to find a PCB that i can populate on my own and dont have to go through the trouble of trying to do a complete layout.
The whole idea of this preamp is to have a clean, accurate and detailed sound with best of both "worlds" tube and analog.
Maybe eventually will add a digital output section as well... maybe...
Here's a small list of all the tube boards DIY Audio Kit offers...
Marantz 7C 7-C Tube Pre Amp
Tube Pre amplifer PCB, Based on McIntosh C-22
Matisse Fantasy Pre-Amp
6SN7 SRPP Tube Pre Amplifier PCB
6N3 (5670) Tube Buffer
Another vendor - 8 Audio has a few too...
Upgraded design for Mcintosh C22
Upgraded Design from Marantz 7
Upgraded design for ARC SP10
Upgrade design for C.J. PV-12
Upgraded design for Cary SLP90
Upgraded design for Jadis JP200
Input please !!
Input please !!
If your requirement is a PC board, I have a couple of recommendations.
For a buffer:
Aikido Cathode Follower PCB
And for a HDMA:
CCDA 9-Pin PCB & Kits or
Aikido 9-Pin All in One Kit
And if you need a power supply:
PS-3
These are original designs, using current design ideas.
They are inexpensive, and well documented.
I was going to comment on your previous choices, but I could not find anything suitable to say. Lets just say I strongly disapprove of knockoffs, especially "enhanced" knockoffs.
For what its worth.
Doug
For a buffer:
And for a HDMA:
PS-3
For what its worth.
Doug
Looking at your list of requirements, if it was fruit you were after it would be something which tastes like apple and orange but looks like a banana!
You seem to want tube sound, SS sound, accuracy and sound processing all in the same preamp. Oh, and both balanced and unbalanced. Then you ask us to choose it for you.
Would you buy a car in this way? Send a friend to choose it, with instructions "I want a small safe family runabout, with turbocharged 4 litre engine, top speed 150mph. Must look sporty, but plenty of room for a major shopping trip. I can't decide whether I want left-hand or right-hand drive."
I only need the tube section chosen as i don't have a lot of experience in tubes. The other stuff is simple to implement.
That actually a simple answer...
Porsche Panamera Turbo or Audi RS4
What do you guys think of this ???
Preamp and power supply
Yes i know, fleabay again but seems like the SP10 had some really good reviews....
So, Input please !!
So, Input please !!
No schematic and it's being sold on the backs of someone else's trademarks. Poor knockoff of (maybe, who knows?) an obsolete and never that great design. Run away.
John Broskie Aikido. Allen Wright FVP. One of my designs at Tech DIY Company Store (disclaimer: I gave the design away and don't make any money from boards or kits). Lots of good boards out there from honest designers. Why support ripoff artists?
hard-wiring a linestage/buffer is one of the easiest things in the world to do. Heck, my very first linestage I ever built was a pair of vintage 71A globe tubes with dual power supplies and a whole bunch of milspec parts I bought from Fair Radio. I just used a Hammond Bud box, drilled holes with a step bit and painted the end results.
Just pick a well known schematic and jump on in.
Thanks for the input guys
As i said earlier, i need a board as it will be housed in a large enclosure with a DAC, a stepped attenuator and source select with a JFET buffer and Tube buffer. Hence why i would prefer a PCB.
Basicly what im trying to accomplish here is a "selectable" output where i can choose between the tube output or the JFET output stage.
- Tubes / Valves
- Need input on Buffer stage to use in Preamp..
