finally finished computer amp!
Finally finished this thing. 6V6 SE outputs, E82CC (SQ 'AU7) gain.
5Y3 CLCLC power supply.
about 4mV hum.
ideas / questions / etc?
Looks nice.
You could think of putting a chromed cage around them thogh, they look a little "vulnerable" like that!
In the tradition of case modding, you must now add cold cathode fluorescent tubes and Blue LEDs to pulse in sync with the sound. :)
And, erm, are the tubes overclocked? :D
Theres no real shielding.. well the wires from the RCA jacks up to the first coupling caps are shielded, but everything else is normal.
Heres the schematic. I suppose I should add some cathode bypasses sometime, but I'm awful lazy, and it sounds good as-is..
I'm not sure on the value of the chokes.. they're pulls from old TV's.
