diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Cambridge Azur 640A V1 Buzz (http://www.diyaudio.com/forums/solid-state/167428-cambridge-azur-640a-v1-buzz.html)
leviathon 24th May 2010 10:43 PM
Still working on other stuff on this forum. Thought the following would be a no brainer. Sigh... :)
Looking to fix my son's integrated. It buzz's upon start-up then (mostly) goes away after about 30 minutes.
Buzz is there without any signal, only speakers hooked up.
Observed that if you turn the volume up, the buzz disappears around the 9 to 11 o'clock area, then starts again.
I have tried cleaning the volume control pot, and all other pots for good measure to no effect. (MG Chemicals zero residue spray)
I still thinking the volume control, but weird that after warm up the buzz fades.
Any help would be appreciated.
Ed
Ian Finch 13th June 2010 02:15 AM
OK Ed, we are here now. Others may follow now with some better advice once inside the amp. I admit I have never checked inside a Cambridge of this Azur species before but some general principles will apply to all SS amps. I believe this is a conventional class AB type and not the XD type of 740 and 840 models. Anyways, I guess we'll hear from you after the father's day activities.
jaycee 13th June 2010 03:00 AM
id look for a bad capacitor in the signal path
leviathon 13th June 2010 05:47 PM
Gaaaa. First thing I realized after I slept in... Father's Day is next weekend, June 20th! So I got that straightened out. Will work with suggestions given. Thanks all!
Ed
Mooly 13th June 2010 06:55 PM
Both channels affected or just one ?
jaycee 13th June 2010 08:21 PM
Listen to the signal at the pre-out sockets. Does that have the buzz too?
jaycee 13th June 2010 08:35 PM
Here's the service manual
leviathon 18th June 2010 01:24 AM
Thanks Jaycee,
Lot of things to test that I had not even thought of to help narrow the problem down.
I will be able to do some poking around this weekend.
Ed
leviathon 20th June 2010 10:09 PM
Buzzing at pre-outs when hooked up to a separate amp and speakers (both L &R), no source! Great tip. That narrows things down. Will start looking at caps, wires and such in signal paths.
Th3 uN1Qu3 20th June 2010 11:18 PM
Since it goes away after a while it's definitely a bad capacitor.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
