diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Twin Audio (http://www.diyaudio.com/forums/twin-audio/)
-   -   New EL34/6CA7/KT66 integrated amplifier (http://www.diyaudio.com/forums/twin-audio/167244-el34-6ca7-kt66-integrated-amplifier.html)
Musik007 21st May 2010 05:25 PM
Our second new tube amplifier in May is available now. The circuit is 6SN7 SRPP drive EL34 class A single end. It's a simple EL34 single end circuit with pure class A sound. The output power is 7W. 6CA7 and KT66 are also suitable for this amplifier.
http://i30.photobucket.com/albums/c3...n7-el34-01.jpg
http://i30.photobucket.com/albums/c3...n7-el34-03.jpg
Dimension of the amp: 365W x 320D(inclu. binding posts and knobs) x 200H mm.
Net Weight: 11.8 KG
http://i30.photobucket.com/albums/c3...n7-el34-02.jpg
Can directly replace KT66 onto the amplifier. It is very easy to listen and experience different sound on the power tubes.
http://i30.photobucket.com/albums/c3...n7-kt66-01.jpg
http://i30.photobucket.com/albums/c3...n7-kt66-02.jpg
http://i30.photobucket.com/albums/c3...n7-kt66-04.jpg
Musik007 21st May 2010 05:33 PM
We now offer a promotional price for this amplifier, USD438 including Russia 6H8C(=6SN7), China Shuguang EL34-B and 5Z3P(=5U4G). The amplifier was designed, made and soldered by Thomas.
Musik007 23rd May 2010 04:20 PM
1 Attachment(s)
This is one of typical layout of tube amp.
Musik007 26th May 2010 03:46 PM
1 Attachment(s)
These are old 6H8C twin triodes which were made in Soviet Union. The specification of 6H8C is same as 6SN7.
Musik007 26th May 2010 04:27 PM
1 Attachment(s)
The output transformers are made with H10 EI 86 x 40 mm x 0.35mm steel cores. The primary impedance is 3.8K and secondary impedance is 0-4-8 ohms. The output power is 15W.
Musik007 26th May 2010 04:53 PM
2 Attachment(s)
Italy made Itelcond 470uF/450VDC electrolytic capacitors handle CLC filtering with choke. High quality and stable.
Musik007 26th May 2010 05:41 PM
1 Attachment(s)
The power transformer is 200VA EI 96 x 60 x 0.35mm steel core. The output voltage is 290V-0-290V/250mA.
We can order the power transformers in other voltages like 100V, 110V and 230V, etc.
Musik007 27th May 2010 04:05 PM
1 Attachment(s)
One pair audio input and no selector used ensures direct signal path. The RCA sockets are CMC long style.
Musik007 28th May 2010 04:45 PM
2 Attachment(s)
There is a speaker output switch at the back. Can select either 4 ohms or 8 ohms on the switch.
Musik007 29th May 2010 04:47 PM
1 Attachment(s)
The voltage of this amp is 220V.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
