if the input V isn't too noisey and variable and the load doesn't vary you can just add a shunt R or CCS "helper' to add current to the output - but generally regs don't pull down so the added current must be less than the minimum draw
more compelx is a current mirror that measures/copies the I drawn by the single LT reg and adds it to the output for double the output - it will require >.6 V headroom
generally you can't simply parallel high feedback amplifier outputs without adding series R - which defeats the load regulation
