For sale. Built two stereo amps, need one...
For Sale - Home made ICEPower ASP1000 Stereo Amplifier Hexateq Chassis. At 1000 watts per channel @4 ohms, more power than you will ever need. These really bring my Magnepan Tympani IVa to life more than any other amp.
I am keeping the Monoblocks as it matches my home-brew Aikido tube preamp better...
The amp modules were installed in a Sleek Aluminum Hexateq Case from Denmark.
Inputs can be switched from Single Ended or Balanced.
Some specs
• 1000W @ 0.01% THD+N, 100 Hz, 4Ω
• 1175W @ 1% THD+N, 1kHz, 4Ω
• 118dBA dynamic range
• THD+N < 0.2%, 0.1W – 1100W, 4Ω
• Bandwidth limit = 38 kHz (8Ω)
• Total efficiency 79%
• Stand-by power dissipation typically 4.1W
• Mains connection is class 1 (with earth)
Looking for $1250.
Some specs
Looking for $1250.
