diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Twin Audio (http://www.diyaudio.com/forums/twin-audio/)
-   -   KT66/EL34 single end class A integrated amplifier (http://www.diyaudio.com/forums/twin-audio/165463-kt66-el34-single-class-integrated-amplifier.html)
Musik007 20th April 2010 04:34 PM
This is our another EL34/KT66 single end class A amplifier. Thomas designed circuit of 6SJ7 pentode in triode connection to drive KT66 or EL34. The rectifier is 5AR4 or 5U4G.
http://i30.photobucket.com/albums/c3...an/KT66-01.jpg
http://i30.photobucket.com/albums/c3...an/KT66-02.jpg
http://i30.photobucket.com/albums/c3...an/KT66-03.jpg
AlejandroR 20th April 2010 06:39 PM
Can you please add more information. output power, number of inputs, price ?
Musik007 21st April 2010 01:24 PM
Hi Alejandro,
In this single end class A amplifier, KT66 is under pentode connection and output power is 7W. There are 3 inputs and 4 ohms and 8 ohms ouptut for speakers.
This KT66 amplifier was well designed and soldered by Thomas. The capacitors were seriously selected. I bought NOS TCC Metalpack 0.25uF capacitors and used between 6SJ7 and KT66. Mcap electrolytic capacitor, 33+33uF/450VDC was used for power filtering. The price is USD650 including Chinese tubes.
Have you received the 6L6 amp?
Thanks.
Tony.
AlejandroR 21st April 2010 01:36 PM
The amp is flying from Miami to Santiago according to DHL tracking. Hope to receive it tomorrow.
Musik007 21st April 2010 01:41 PM
3 inputs and 4 ohms and 8 ohms outputs for speakers. The AC input is 220V.
http://i30.photobucket.com/albums/c3...an/KT66-18.jpg
http://i30.photobucket.com/albums/c3...an/KT66-19.jpg
http://i30.photobucket.com/albums/c3...an/KT66-21.jpg
Musik007 21st April 2010 01:47 PM
Great!
Quote:
Originally Posted by AlejandroR (http://www.diyaudio.com/forums/twin-audio/165463-kt66-el34-single-class-integrated-amplifier-post2161278.html#post2161278)
Musik007 21st April 2010 02:27 PM
KT66 is a high slope, indirectly heated beam tetrode designed principally for use in the output stage of audio amplifier. The KT66 was essentially a 6L6 redesigned with a larger cathode and a shorter, fatter anode.
http://i30.photobucket.com/albums/c3...an/KT66-04.jpg
http://i30.photobucket.com/albums/c3...an/KT66-05.jpg
KT66 @ The National Valve Museum
Musik007 21st April 2010 04:02 PM
Electron KT66 (Made by Shuguang, China) is a nice KT66 with good construction. The price is affordable.
http://i30.photobucket.com/albums/c3...an/KT66-08.jpg
http://i30.photobucket.com/albums/c3...an/KT66-07.jpg
Musik007 23rd April 2010 05:17 PM
Dimension of the amplifer: 340W x 280D (including knob and binding post) x 185H mm
N. W.: 12.5 KG
Musik007 24th April 2010 05:09 PM
Russia re-issued Tung-sol KT66 is also worth to try.
http://i30.photobucket.com/albums/c3.../KT66SE-38.jpg
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
