I just received parts from Digikey for my opamp based active crossover.
I realized that that the 1% precission resistors I ordered are rated 1/4W. Is it going to cause problems? I'll be using a +/-15V power supply, but feed a consumer signal (-10dB) to the crossover. The opamps are NE5532.
So, with input signal in the 3V range max will I exceed the resistor rating?
here is the pdf link:Panasonic resistors
TIA
TIA
