diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Full range as inexpensive nearfield studio monitor (http://www.diyaudio.com/forums/full-range/159944-range-inexpensive-nearfield-studio-monitor.html)
zog666 26th January 2010 01:26 AM
Any opininions of using a full range driver as a low cost nearfield monitor for music production?
Been reading up on the Markaudio CHR70, and one of these looks like it could be good for a low/medium volume desktop/bookshelf monitor system, combined with a Lepai amp or similar to drive it... the lack of crossover I am guessing will keep the cost down while also preserving detail and coherence (respective to the pricepoint of the parts) as there is no crossover point to worry about.
markaudio 26th January 2010 05:19 AM
2 Attachment(s)
Hi Zog666
Here's 2 projects done by guys here in Hong Kong.
1 - Mini-mons - black vinyl covered BR's made by Roger Young. He runs them with a sub. size is 170-mm wide X 180-mm high X 180-mm deep. I'll see if Roger has time to join up and comment.
2 - Tony's larger BR in re-constituted Oakwood. Size is 150-mm wide X 290-mm high X 190-mm deep. The wood is 20-mm thick. He's making these in his spare time.
Both are using the Gen.2 CHR-70's. Roger has just swopped from the first gen gold model to the new champagne CHR. So we're hoping to get some listening time over the Chinese New year in his apartment.
I think there's allot of guys on the forum who've used the CHR-70 in near-field and Desktop. It could be well worth doing a search on this forum.
Cheers
Mark.
zog666 26th January 2010 05:54 AM
Quote:
Originally Posted by markaudio (http://www.diyaudio.com/forums/full-range/159944-range-inexpensive-nearfield-studio-monitor-post2061682.html#post2061682)
Hi, thanks for the feedback! Yes the small bass reflex you show looks ideal. I've already searched pretty extensively on the forum, but people mainly make reference to them for listening to music or multimedia (want stuff to sound good) rather than mixing/producing audio&music (want sonic deficiencies to be revealed).
That said my newer hobby of DIY audio building seems to have taken over from music production....
markaudio 26th January 2010 06:12 AM
Ummmmph, I'm thinking you may want to take a look at the new Alpair 7. It's more or less the same physical size as the CHR-70 but a big step up sonically. This driver may possibly provide more for your needs.
It's new but there are some threads and posts emerging which help you:
http://www.diyaudio.com/forums/marka...lpair-7-a.html
http://www.diyaudio.com/forums/full-...plication.html
Cheers
Mark
planet10 26th January 2010 06:22 AM
Quote:
Originally Posted by zog666 (http://www.diyaudio.com/forums/full-range/159944-range-inexpensive-nearfield-studio-monitor-post2061478.html#post2061478)
A very valid idea.
I have a film maker using a set of mFonken for his nearfield monitors.
I loaned a set of Fonken to a local radio station and they really liked them for that purpose. They were just afraid they were going to blow them up. Now i have the EL70eN in the "same" box (Mar-Kel70), and it would be even better for the purpose and much less likely to have the smoke released.
dave
gvimhoof 27th January 2010 03:01 AM
I also agree that this is a very valid idea. If you don't have the money to spend on high end studio monitors then you can do very well by building your own. If I were to do this for myself, then extended-range single driver would be the first pair. Just make sure you tell your clients that they are "custom made"- not DIY.;)
Then also something cheap and not-so-nice to mimic what the majority of people listen to recordings with (a sad reality). I know a large commercial studio engineer who keeps a pair of NS10's for mastering: "If I can make it sound good on those, then it'll sound good on anything."
zog666 28th January 2010 08:34 AM
Thanks for the input.. so it looks like they would make good monitors for environments not blasting a lot of volume (lower power handling).. the Alpair 7s would definately be better than CHR70 though they would also increase the cost, which is fair enough.
Aprilinee 28th January 2010 10:49 AM
Hi I'm new here, and I'm looking to build something simular.
Is it possible to put the alpair 6 or 7 in the sealed box, wich John K. uses for the Hivi B3s?
Zaph|Audio
I prefere the looks of the alpair above the HiVi.
Snatchman 2nd November 2014 03:44 AM
Hello..I'm also new here and asking some of these same questions so if I may, can I join this thread?..I'm looking at the Alpair 7.3 drivers in a Brines Acoustics A7 cabinet..This cabinet size works for me and the design doesn't seem too hard to " custom" build ( not DIY)..:D..Would like to use in a tracking/mix scenario..I mean c'mon, if people mixed on 4" Auratones for decades ( still do) the 7.3's in a good designed cabinet should work huh? (;))...Thanks..!
xrk971 2nd November 2014 09:06 AM
Here is a low cost option for nearfield and moderate volume levels.
http://www.diyaudio.com/forums/full-...dcr-tc9fd.html
$12 driver and $9 in BSC components.
http://www.diyaudio.com/forums/attac...-polar-all.png
Distortion:
http://www.diyaudio.com/forums/attac...g-hd-final.png
Impulse:
http://www.diyaudio.com/forums/attac...g-ir-final.png
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
