Supplemental question to my previous post (need some basic theory here). Assuming I use this amplifier:
4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board - eBay (item 220508931371 end time Jan-10-10 00:42:59 PST)
and I power it with some old 100W laptop battery. Can I easily do serious damage to the amplifier, or would I just be getting way less power than I paid for?
thanks, Bill
thanks, Bill
Wsmckenz-
welcome... first off I would avoid the 4x100 module. Many people have reported trouble with them. It's a little more expensive as you would need 6 of them instead of 3, but I would get their 2x100 boards.
People have been using these power supplies with success (one per board, though you could probably get away with 1 for two boards if you had to). As far as under powering the amps is concerned, they have a range of 10-36 volts if memory serves me correctly, I certainly wouldn't go outside of this range. As far as current is concerned, certainly the higher current power supply tend to sound better, but I doubt you will hurt the amp by under powering them. You might be dissapointed in the sonics though.
Joe
Joe
