diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   ucd400 st or coldamp (http://www.diyaudio.com/forums/class-d/157289-ucd400-st-coldamp.html)
Session 24th December 2009 12:36 PM
I can get 2 ucd400 ST or 2 COLDAMP for the same price. What do I choose?
Mery x-mas!!
theAnonymous1 24th December 2009 01:14 PM
Well, I think the choice is obvious. ;)
luka 24th December 2009 02:34 PM
Quote:
Originally Posted by theAnonymous1 (http://www.diyaudio.com/forums/class-d/157289-ucd400-st-coldamp-post2023498.html#post2023498)
It is? I would probably in the eng go with ucd, but i'm sure nothing is wrong with coldamp
theAnonymous1 24th December 2009 03:51 PM
Quote:
Originally Posted by luka (http://www.diyaudio.com/forums/class-d/157289-ucd400-st-coldamp-post2023570.html#post2023570)
It is?
Yes. :p
Given the choice of one vs the other, I see no good reason to choose Coldamp over Hypex.
I don't think you can go wrong with either though. Wish I could afford a pair!
Session 25th December 2009 11:54 AM
Even though we keep in mind this is ST and not HG?
luka 25th December 2009 07:50 PM
also based on where you like, maybe ucd would be better choice
Ltralus 25th December 2009 08:08 PM
Actually you can go wrong with one of them. Engineering has no political correction factor, folks.
luka 26th December 2009 12:02 AM
Quote:
Originally Posted by Ltralus (http://www.diyaudio.com/forums/class-d/157289-ucd400-st-coldamp-post2024479.html#post2024479)
explain
glt 26th December 2009 03:14 AM
See postings from bgt, like this one: http://www.diyaudio.com/forums/class...255-amp-9.html
Ltralus 26th December 2009 06:41 AM
Quote:
Originally Posted by luka (http://www.diyaudio.com/forums/class-d/157289-ucd400-st-coldamp-post2024581.html#post2024581)
explain
While engineering has no political correction factor, commercial forums such as this most certainly do. Given that, it would be best if perhaps you explained your assertion of their equivalence. We may then look to the third party measurements one manufacturer was embarrassed by, but as they provide none of their own it's the most we've got to work with when making an informed decision. Following that can be a discussion on the perils of poor layout decisions in a class d environment, as someone who had a forum design over 90% of their product is likely to make. Much of that you can spot with the naked eye if you know what to look for. Putzeys has an article detailing these very things, which was inspired by this very amp.
Glt, I would put no faith in that. It's too much akin to saying if you cut everybody's legs off at the knees we'd all be the same (?). Somehow it just denies big picture.
Session, bear in mind the ST was the basis for the HG. The HG is quite a bit nicer, but they share the very same solid foundation. The HG is demonstrative of the kind of potential the ST holds if you're so inclined.
In stock form it has all the desirable features of an audio amplifier that many others struggle with like flat load independent frequency response, and virtually load independent low distortion. Critical to performance and somewhat rare in the field as its mastery over EMI. That translates to higher sound quality and ease of use from (ab)user perspective.
The main steps required to take it well beyond the standard or even the AD quality level would be a high quality, well regulated auxiliary supply to feed the input stage with, and of course addressing the electrolytic AC coupling capacitor issue. These are both simple and affordable as you really don't have to go all out on expensive or exotic components to reap the majority of the benefits from doing it. It is unlikely that "alternatives" have such potential to unlock at all, let alone so simply, and it's the combination of everything that makes the choice so obvious. Even the ST can still be a giant killer.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
