diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   PIC programming (http://www.diyaudio.com/forums/parts/15219-pic-programming.html)
future 16th May 2003 04:58 AM
PIC programming
Does anyone have a PIC programming howto/guide/course?
Post here please or send by email.
mhennessy 16th May 2003 08:43 AM
If you're a complete beginner, there's some stuff on my homepage that will help you get started.
There's nothing there (yet!) about writing code for the PIC, but the following links should prove useful...
Introducing the PIC -
Guide to use the PIC -
Technical Reference -
Hope this helps,
Mark
jackinnj 16th May 2003 10:07 AM
Microchip has helpful "starting out"
on their website.
Personally I use PicBasic Pro with some occasional assembly language every once in a while.
Rarkov 16th May 2003 11:07 AM
sorry, but you can't beat the free JAL. based on Pascal and stupidly easy...I never touch ASM but you can if you want to, it can be embeded into JAL.
Have a look...+ with one of the BEST mailing lists, it's the place to start with PICS.
Gaz
peranders 16th May 2003 11:11 AM
Quote:
Nice looking preamp!
till 16th May 2003 01:06 PM
there is a very good but german tutorial at http://www.sprut.de/electronic/pic/index.htm
on the net.
there are some usefull examples like voltmeter, counter etc. sample programs and circuit. You could try to translate what you donīt understand with google or email me with questions., i know the site very well now.
mhennessy 16th May 2003 01:30 PM
Quote:
Thanks! But it's not as nice as some of your stuff. Do you get your PCB's professionally manufactured?
Your headphone amplifiers make mine (1 op-amp plus 2 transistors) look a bit silly ;)
davesaudio 16th May 2003 01:44 PM
the al williams tutorial is nice
wouter has a good intro on his site via the JAL link above
the JAL list is a yahoo group-took me a while to find it
GUILHERME 16th May 2003 02:13 PM
The MicroChip site (www.microchip.com) is loaded with useful info and software. You'll find a free assembler/debugger (MPLAB), the schematic of a programmer that connects to the pc parallel port, a bootloader for pics having a UART, and so on...
And of course, reference manual of each pic model.
BTW, I've written an utility that takes a .hex file and programs a pic using the parallel port programmer from an application note as described above. It uses the routines of the AN but can work on NT/2000/XP machines (which the original routines can't because they use biosprint).
If you or anyone else wants it, I can try to put it in a package and post it here for download (I'll have to check dll dependencies first).
best,
Guilherme.
Matttcattt 16th May 2003 02:57 PM
http://www.winpicprog.co.uk/ there is some free software, and a good tutorial, i tought myself with it :D
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
