Any ideas? the original filter cutoff was 45hz. However, after modifications, I managed to get the filter down to 35hz. I want to drop it down to 25hz. The filter is based around a TL084 op-amp. What components would determine the low frequency cut off point? I've added an extra pot which allows me to modify the Q factor. And increased the value of some polyester capacitors within the main filter circuit. However, only reduncing the cutoff by approx 10hz. The DC blocking capacitors are 4.7uf. Would I need to increase those in value?
Any help, or links would be greatly appreciated.
