diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Indicator LED mounting i thick front panels (http://www.diyaudio.com/forums/parts/148413-indicator-led-mounting-thick-front-panels.html)
NicMac 1st August 2009 09:55 PM
Hi All,
I need to place a series of LED's (3 and 5 mm) in a think aluminum front panel (10 mm) and I'm not sure how to do this the right way. I would like the LED's to stick out slightly (the round part).
Is drilling a through hole of 5 mm (for a 5 mm LED) followed by expanding this hole to 6 mm to the desired depth (a few mm before the front) the way to go or is there a simpler way?
Thanks in advance,
Nic
Magura 2nd August 2009 08:39 AM
Yes, that's the way to go.
Magura :)
Andersonix 10th August 2009 06:56 PM
There are also plastic LED holders/bezels meant for mounting in sheet metal that could be adapted to fit a deeper hole, but they have a trim ring that's visible.
NicMac 10th August 2009 09:06 PM
LED's with a flat front anybody......
I guess 10 mm front panels are rare in consumer electronics and that this is probably the reason there is so little around (I can find >10$ things which require a 10 mm hole but it is not of my taste and purse...
Thanks,
Nic
Andersonix 10th August 2009 11:53 PM
2 Attachment(s)
Why didn't you just ask this first?
I stocked up on the ones shown here. They're flat and 2mm OD at the tip. I found red ones in a surplus shop (and orange ones in another).
Andersonix 10th August 2009 11:57 PM
2 Attachment(s)
...and now I use them everywhere. (Shown here in 3/8inch thick aluminium with a recess)
But I have also filed down normal LEDs so they're flat...
mightydub 11th August 2009 05:33 AM
Nice! I take it you have access to a CNC mill - I'm envious.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
