diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Tube amplifier (http://www.diyaudio.com/forums/tubes-valves/146748-tube-amplifier.html)
jackand08 30th June 2009 05:10 PM
Tube amplifier
Hi everyone, just wondering as I am about to build my first tube amplifier is the attached design o.k. and also does anyone know a suitable replacement tube for a 6AU6 driver tube and a 5Y3G rectifier.
Here is the amplifier schematic...
http://www.instructables.com/files/o...KGFWEGK7VT.jpg
...and the power supply schematic.
http://www.instructables.com/files/o...T4FWEGK7Q6.jpg
oldmanStrat 30th June 2009 05:53 PM
Why do you want to replace the 6AU6? Looks like it's a pretty cheap tube. Found them here: http://www.esrcvacuumtubes.com/vacuu..._6A3-6CZ5.html
as well as the 5Y3G.
The only comment that I have is that there is a lot of feedback in that design...
jackand08 30th June 2009 06:23 PM
I need a replacement for the two tubes as I live in the UK and cannot find a UK supplier that stocks them. I don't want to order form the US because of the high postage costs. Also, if a suitable replacement can not be found could someone possibly give me a website address of a UK supplier that stocks the 5Y3G and the 6AU6.
Tom Bavis 30th June 2009 08:31 PM
EF94 is same as 12AU6 - can you find that one? 5Y3 should be available, (perhaps Russian) but U50 or almost any GZ... number will do.
Eli Duttman 1st July 2009 02:28 AM
Other than the cathode sleeve, the GZ30 is pretty much a 5Y3. Make sure to take the B+ from pin 8, not pin 2.
A 6AU6 data sheet is here .
A German EF94 data sheet is here.
colinB 1st July 2009 07:12 AM
A good source for valves in the UK is Langrex. They stock all the valves you need for your build.
http://www.langrex.co.uk/
Cheers
Colin.
ray_moth 1st July 2009 10:40 AM
I don't know who Michael Holden is, but that design bears a more than passing resemblance to
this design from J.E. Calvert in 2001
chrish 1st July 2009 10:44 AM
On the link you refer to, the schematic is credited to the RCA Receiving Manual, so perhaps it is from there...
ray_moth 1st July 2009 10:51 AM
Yes, you must be right, I didn't notice the label in the schematic. I was going by the credits at the foot of the page -
Composed by J. B. Calvert
Created 30 October 2001
Last revised 2 November 2001
Looking at the circuit, the operating points are strange, don't you think? Whoever runs a 12AU7 with a 220k plate load? 330k for a 6AU6 plate load is also odd, because it suggests a very low plate current for a tube that, as far as I know, runs best with about 3 to 5 mA plate current.
Gordy 1st July 2009 11:18 AM
If Langrex run out, and if you can't source them in the UK, then Antique Electronic Supply has both tubes in stock. (Don't get hung-up on the price of postage. The last time I ordered from them it was only about 25. Instead think about the overall cost of getting the job done quickly and effectively).
Their site: http://www.tubesandmore.com/
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 18.75%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
