diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Grimm Audio LS1 ... an SL-approved *box* monitor ? (http://www.diyaudio.com/forums/multi-way/144968-grimm-audio-ls1-sl-approved-box-monitor.html)
gainphile 29th May 2009 08:04 AM
Anyone heard of this one?
http://www.grimmaudio.com/ls1grimm.htm
A sensibly designed loudspeaker
On the exhibit floor of the 129th AES Convention in Munich I saw a loudspeaker that impressed my by the logic with which it was designed, the GRIMM AUDIO LS1. I could not listen to it closely because the surrounding noise level was far too high, but what I saw and heard from the exhibitors convinced me that the LS1 is a remarkable loudspeaker design. The wide baffle yields a forward pointing and smooth polar response over a very wide frequency range with a low transition frequency region to omni-directional behavior. The inside of the box and the panels appeared to be properly designed. The speaker is active and uses intelligently applied DSP for response correction. A subwoofer can be correctly integrated if needed. One can only hope that the LS1 breaks bad habits in recording studio and home. -SL
http://www.grimmaudio.com/images/LS1.jpg
JoshuaTechnomage 1st June 2009 12:29 AM
Hmm.. Anyone know if that woofer is an 18W8535 or 18W8545? (I would guess it's a 8535 because of the sealed enclosure design)
rhodes54 17th November 2009 11:14 AM
I've heard this monitor twice. Last time was about a week ago and this version is the one which will be taken into production.
All I can say is that this is one of the best monitors I've ever heard. It is fast as the speed of light and musical at the same time. Transients are fired at you like missiles and the stereoimage is just breathtaking. Everything is just there at the moments it should be there.
By the way, both the tweeter and low/mid driver are different in the latest version
LittleMajorMastering 5th July 2012 12:00 PM
Quote:
Originally Posted by rhodes54 (http://www.diyaudio.com/forums/multi-way/144968-grimm-audio-ls1-sl-approved-box-monitor-post1983669.html#post1983669)
rhodes54 is right! I even quoted him on my website: Information about Little Major Audio Mastering
look under "Gear"
Cheers
Philip
Little Major Mastering
DrDyna 5th July 2012 03:50 PM
Looks like a cute little speaker, I wonder how much they're going to cost.
LittleMajorMastering 5th July 2012 03:56 PM
Well it's not little, but it's cute!
and the sound is unbelievable
and the price is approx 12-15000 Euro (with or without remote)
Cheers
Philip
http://www.littlemajormastering.info
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
