PS response
The Trends 10.1 comes with a power supply.
The ideal unit for the Trends would be a 12 volt supply that supplies 3 amperes or more. However there are a lot of tweaks that can be made to the unit which will enhance its performance without having to upgrade the power supply.
Re: PS response
thanks i have tweeks covered on the amp (case/caps/copper shielding for the inductors/etc) it was just the voltage that i need to get right, i have heard i can use between 12-13.8 volts but is there a sweet spot that is best?. when i order my power supply it will be adjusted to that voltage and i thjnk it is not user adjustable, that why i want to get it right the first time. thanks
Davet said:The Trends 10.1 comes with a power supply.
panomaniac said:Hi Jeremy
If you can get your power supply adjusted for 13 volts, do that. If not, 12V is OK. 13 just gives you a little more headroom. I don't like to go over 13V with this chip.
thanks for the info, also what about the amperes how many is ideal! 3/5/?. thanks again.
