Hey everyone...once again I want to thank you all for coddling this newbie.
Next ? ...I have a chassis from an old Magnavox console stereoand I was wondering if I can use one of the output trannies in a single-ended amp ? It seems logical to me since it was being driven by a single EL84 into a single speaker, that as long as I match primary and secondary impedance, it should work. Yes/no ??
Also, the PT I am using has a 6V rectifier tap...the amp it is in has a 6X4 rectifier..can I use a 6X5 rectifier with it ? Only because I have some 6X5s around and lots of octal sockets....thx again !!!
B.Bill
B.Bill
bereanbill said:I have a chassis from an old Magnavox console stereoand I was wondering if I can use one of the output trannies in a single-ended amp ? It seems logical to me since it was being driven by a single EL84 into a single speaker, that as long as I match primary and secondary impedance, it should work. Yes/no
Yes.
Yes again since the filament current requirements are the same, 0.6A. BTW, the tube voltage drop is also the same, not that it matters so much. (22V at 70mA)
