I replaced 2 16000uf PS caps in a Bedini 801 amp with Cornell Dubilier 33000uf. Both are rated @ 75VDC. Amp was quiet when 1st turned on. I put a cd in & got sound out of Rt channel & only a little static out of LF side, no music. I turned amp off & then on again & the rt channel began to distort. Immediately turned it off. I bought the caps on EBAY on EBAY over a year ago which were represented to be NEW!
CD- Part no is 500333u075cd2bnt HOPE THIS HELPS IN DIAGNOSTICS!
