The daunting world of tubes (where to start)
Hello everyone,
I have a previous post in the solid state section re: Class A and someone directed me to tubes so I'm hoping someone may help.
Firstly I'll tell you what I am trying to achieve; I play vinyl and last year purchased some AKG701 headphones for private listening, it was whilst playing a mobile fidelity recording that I noticed the ghosting on the opening track i.e. the track starts before it actually starts. I cannot reproduce this through the speakers however despite any volume setting. This brought me to the conclusion that my integrated amp was losing a lot of detail in the system and as my headphones plug into my amp the equipment prior to this was obviously able to extract this information.
So now my search begins for a truly transparent amplifier that allows every ounce of detail to flow through.
My questions are as follows;
1. Am I on an unfulfillable quest?
2. Can anyone suggest any kits or amp designs that would help me get to where I want to go.
My speakers are the Wilson Benesch Arcs, 88db on axis 2.83V, 200W max unclipped, 6 ohms nominal 4ohms minimum, 111db max SPL.
Many thanks in anticipation,
Mark.
Mark,
Let's do a little math, 1st. It's necessary to treat your speakers as being 4 Ohms, when combined with tubed power amplification. 2.83 V. into 4 Ohms is 2 W. Therefore, your speakers are 85 dB. efficient. Paul Joppa has provided us with a useful rule of thumb. Joppa's Rule states that an amp/speaker combo be capable of 102 dB. SPL peaks, in an "average" sized listening space. That means you need at least 60 WPC.
It takes "coin of the realm" in considerable quantity to build or buy tubed power amplification of the sort being discussed. Are your pockets DEEP?
Frequently, the practical solution for speakers like yours is tubed preamplification combined with "top notch" SS power amplfiication.
Thats interesting, how did you come to that calculation?
It depends, if its the choice of spending say £3000 - £5000 on a commercial amp or building something far superior, I would opt for the build but only if it was right so I would build a sample amp first i.e. a down scaled version.
Yes, I have a post on the SS forum re the Class A approach and have considered a tubed pre-amp separate but was steered in this direct by some fellow forum members in order to help me achieve my desired goal.
It starts to feel as if I'm going in circles, there are so many options :bigeyes:
You could do a push-pull (PP) 6550 or KT88 amp to get the kind of power that you need. It won't be class A or anything single-ended if you need the watts (at least with a single pair of tubes per channel), but may not be unreasonable for a beginner tube project, depending on your experience and comfort level working with high voltages. Power out is dependent on your B+ voltage (among other things), so that is something to think about.
Those tubes in PP can get 60W or so in pentode config and somewhat less in ultralinear mode (Eli or one of the other experts can be more specific on this)
Search this forum for 6550 or KT88 ultralinear designs or pentode designs to get an idea.
I would imagine that one could build an amp based on the above tubes for sub-$1000 fairly easily, although putting $$ into the output transformers is usually well spent.
Ex-Moderator
Joined 2004
Mark,
At the risk of boring your socks off, please be aware that high voltages are involved in tube amps. If you're not experienced in dealing with this hazard, you should acquaint yourself with the facts and precautions before getting involved. This thread contains some warning of what to expect.
Eli's response may not seem vary encouraging but he's only telling it like it is. With tube gear it's normal to see speakers of higher efficiency. 85dB is low and, as Eli rightly says, will require an amp of high power (for tubes) to be able to drive it with ample headroom for transients. 60w for an SS amp is no big deal, but for a tube amp it is, in terms of both cost and technical challenge.
A Class A specification makes things more difficult still, because it means low efficiency and high quiescent current, that is, the OP stage is running flat out all the time, even with no music paying, and you get out relatively little power. A 60w Class A amp is a monster IMHO!
You also need to be aware that such a tube amp will be big, will give off lots of heat and will need protection to prevent it from being touched by people, especially children, who are unaware of the dangers.
In conclusion, I would echo Eli's advice that you either invest in high efficiency speakers that are more tube-compatible, or you try to find a better SS solution for the speakers you have.
Mark,
Boywonder's remarks about Class "AB" KT88s are spot on. As the owner of a Harman/Kardon Citation II, I can state, without reservation, that PP KT88 amps are FINE, when done properly.
To give you some idea of the costs you will encounter, a UK winder of magnetics, Sowter, offers the suitable model U070 O/P trafo. That "iron" costs 180.42 UKP plus VAT each.
Practical considerations, especially safety, dictate that you build some sort of preamp prior to attempting a near 500 V. B+ power amp. Some commercial receivers and integrated amps have a preamp-out/amp-in feature. Should the equipment you currently possess have said feature, DIYing a "hollow state" line stage to work with it would (IMO) be a very good idea.
As for how I arrived at 60 WPC, that's easy. Each 3 dB. increase requires a doubling of power. If 1 W. yields 85 dB., 64 W. yields 103 dB.
There's something not right here:
My earlier reference books (and there are alot of them about) quotes o/p stages with power 10-15W is suitable for the average living room; large rooms and small halls 15W upwards. I think Joppa's rule is based on MI and not hi fi. Please correct ?
To me the size of the average living room in an European house has actually shrunk half the size of a 1950's grandee.
My little 25W amp has considerable prowess when compared to the 150W bemoth, the latter requiring a serious approach to dedicated bench work and I question whether the time and expense is worth it.
richy
Thanks everyone for your responses, albeit not necessarily what I wanted to hear.
Yes I think I will thanks.
Practical considerations, especially safety, dictate that you build some sort of preamp prior to attempting a near 500 V. B+ power amp. ....... DIYing a "hollow state" line stage to work with it would (IMO) be a very good idea
I think the pre-amp idea may be the way to go for me, at least to start with so I can get a feel for tubes.
Thanks for the warning, no worries about that, I am very aware and have worked with mains and live unfused mains before although not power supplies like transformers. After being electrocuted a couple of times, I am quite cautious now :cannotbe:
...subtract 6dB for listening in stereo, and since a majority of power is consumed in the bass region, subtract a little more for room gain, given the bass is being reproduced by a direct radiator.
READ THIS
Marko,
Welcome to the wonderful (albeit confusing) world of tube audio.
I myself are a relative "newbie" to the this interesting hobby. To put into "laymans terms" a lot of what has been posted and to maybe clarify some things for you from the perspective of a "newbie" also.
1: Reason for treating your speakers as 4ohm load is that tube equipment is VERY impedance dependant and also quite fragile when the load encountered is low. By having the clear spec's of your speakers we can infer a 4 ohm nominal load for the Output transformer calculations.
2: The overall power output requirement is going to be dependant on listening position, room size, your personal taste etc. As a "frame of reference" from someone who has very recently "been there and done that", I am listening right now as I type Carlos Santana "Moonflower" played thru a set of Yamaha's A-636's (smiliar SPL to your speakers) I am about a meter away and pretty much "dead set on axis" with them.
My 6V6PP amp is only capable of about 8 watts/channel max (which I cannot see with my limited input signal voltage) so I fgure I am pushing only about 4 watts class A.
I do not have a dB meter but the level is more than adequate (for example I would not be able to hear someone talking at a normal conversation level even 6 ft away)
I can go to my work area 20 ft away and still have a nice listening level with this setup.
3: As noted a Class A Tube amp with 60W output would be a MONSTER. Even in Parallel Push pull class A would be pretty hard to reach and need some pretty pricey tubes.
But that being said, IMHO there is nothing that I can afford in SS that even approaches the sound of my humble little "junkbox" 6V6PP. If I were to build it from the ground up with commercially available higher quality components my cost (excluding hours of personal labor) would barely top $2200 US. That is putting serious money into the "iron" and capacitors.
On a budget it could easily be built for about $800US and be infinately better quality than what I personally have.
4:) I am in no way stating you should run right out and start slapping together a 6V6 PP amp.
What I am stating is this.
If you are not afraid of voltages that can KILL! (No JOKE) and will seriously respect that.
If you have decent mathematics skills.
Learn Ohm's and Watt's laws backwards and forwards.
Can strip wire and solder reasonably well
Can read a schematic.
Then you can probably build yourself a nice amplifier. Considering the budget that you seem to be prepared to expend you will not regret the choice of tube amplification.
As a Newbie here are my recomendations if you are prepared to venture into the realm of DIY.
#1) "GOOGLE" is your friend! Start looking for published schematics. Download them and look them over. Try to understand a little of the overall topology and theories. It will not take long to see many "common threads" in the many many designs out there.
#2) Get yourself a copy of an RCA Tube manual. RC-30 is a good start. Read the sections on resistance coupled amplifiers and Tube applications. Perform some of the math excercises that are in there.
#3) A "preamp" might be a place to start but since you are not 100% sure of where your SS equipment is lacking you might consider a relatively easy and inexspensive "integrated" VT amp as a first project this way you can have a taste of the whole project with a reasonably guaranteed outcome.
"Mistakes" that I made that I might help you avoid.
Do not approach this as just a "Build A Kit" and I now know about tubes project. Learning the "basics" from the available info is well worth it. By now understanding the theory and characteristics of tubes from all the reading and practice I can look at a schematic and make calcs of Power Out and Distortion etc. This helps me to understand what that particular design will result in.
To get a sample of the "sound" you could look at an SE design (by default all SE has to be Class A) that makes somewhere in the 4 to 5 watt range with maybe 6BQ5 (EL84 "across the pond").
Or for a less expensive approach as far as OPT's a Push Pull circuit using similar tubes and gives a doubling of relative power along with less distortion.
I have found that I like the sound with Tube Rectification but that is just an opinion.
Also for ease of constrution on a first project Self Bias is a good idea.
Hope this helps in some small way!
Hi Marko,
Good advice preceeding this, so on this vast subject I would not like to repeat.
But folks, are we not missing something here??
Marko25 said:
....it was whilst playing a mobile fidelity recording that I noticed the ghosting on the opening track i.e. the track starts before it actually starts.
This brought me to the conclusion that my integrated amp was losing a lot of detail in the system and as my headphones plug into my amp....
No.
The well-known 'ghosting' on some vinyl records is part of the input signal, and I am not aware of any topology that is amplitude selective as in losing low amplitudes. In this sense one must look elsewhere for the noticed difference, not at the type of amplification.
I am at a loss to exactly explain your experience, unless you played the headphones at quite a volume, such that you noticed the very low ghost signal there and not on the loudspeakers. But you stated that you tried loudspeakers at all volumes .... It can also not be that the low signal would be lost in background noise on the loudspeakers; for that the noise would have been very noticable and you would not have put up with such a system. Strange ...
With this I am not shooting down any interest in tube technology - I come from the era, so to speak. But they will not be more transparent than good solid state equipment; in fact, academically it should be the other way round.
I am not sure exactly what he is hearing as I am not a big " Vinyl Guy" But I do know that for some reason I "hear" things now thru the tube amplifier (exact same source, same drivers, same room, same tracks) that were either previously inaudible or masked somehow with SS amplification. I have had all manner of receivers/power amp in SS over the years. Some cheap and dirty some higher end stuff. I honestly prefer the tube amp.
Now for my "Home Theater" in my family room where we watch movies and "impress" friends, I have Solid State. It is used rarely and makes a "lot of noise" Especially my handbuilt 12" subwoofer cabinet with 200W plate amp. For all the new digital surround sound effects etc SS is the way to go. But the last time I checked I have TWO ears. So most of the time 2 speakers is good enough for me.
Marko,
I still suggest a foray into "Hollow State" you will not be sorry. I find that there is nothing more satisfying than listening to one of your favorite tracks on something that you "built yourself".
Tube Info
Great earlier post 'cold cathode'.
Mark,
As you've probably noticed from the responses your getting, tubes will always be dear to those of us that grew up with them.
I bought 2 Velleman K8010 kits in 2001 at a great price of $800.ea
These are beautiful PP Quad Pentode KT88 Amps, although Velleman tends to use some cheaper components. I learned allot more about tube circuits in the process of 'Mods' on these and am pretty happy with them now (regardless of what Aqua Blue thinks).
They sure warm-up the 'feel' of my living room at night.
Me I'm still trying to figure the new world of solid state and digital, somewhat your situation in reverse. There is a lot of great information out here on tube amps. Suggest you casually read some of the better articles available verses trying to learn 'textbook' style.
One of my favorites, I've re-read many times: Articles by John Broskie at : John Broskie's Guide to Tube Circuit Analysis & Design
http://www.tubecad.com/
His initial writings beginning March 99 address the newer generation that has little knowledge of tube circuit design: He does an excellent job of it; tying modern solid state circuits to their actual tube predecessors and tube circuit equivalents.
We have to thank DIYAudio'er Nigel 'thevoice' for mirroring Steve Bench's great website at:
http://greygum.net/sbench/sbench101/
Of course any of the issues of 'Glass Audio' that can be obtained through AudioXpress.
Here's a build for you":
http://www.audioxpress.com/magsdirx/ax/ax-glass_audio_special05.pdf
AudioXpress's 'Audio Classroom Series'
http://www.audioxpress.com/resource/audioclass/index.htm
Many more good references are out there, Sorry I know I left some out. We love our tubes!! Don't get me wrong; I'm in the process of a Pass F5 build right now, everything has its place.
Charles
I challenge "Joppa's rule" for the very reasons given already - rooms have shrunk in Europe in particular. I live in a block of flats where all the original flats have been divided in two and sold off to residents - not unusual at all where people are after a foot on the housing ladder. I and several friends now drive panel speakers - Apogees, Magnalpanars - with DHT amps of 10 watts up to 15 watts. And such panels are insensitive. Also music listened to in our case is classical and jazz - essentially background listening - not techno music for dancing to. That'a a set of circumstances which makes a 15 watt amp just fine. I leave it to the OP to see if these circustances sound similar to his.
I think that if you are going to really benefit from this experience of building with valves, you need to think in terms of push pull DHTs, and that points straight at 300b outputs as the usual solution for 15 watts. They are the highest outputs for DHTs at sane voltages, and are a superb valve.
I and several others (though not the majority of valve users I must be careful to say) believe that to get the full finesse and detail out of the music directly heated triodes (DHTs) are the way to go. So if they're right for outputs they're right for input and driver tubes too. It's going to be much easier for you not to use DHTs for the input - choose a design with 6SN7 s for instance, or use a two stage amp with a high gain triode into a transformer phase splitter such as Lundahl LL1660/10mA. If you truly want a killer amp, use 01A into 46 into 300b. That means DC filament supplies for EACH 01A and 46 (and 300b if you want to go DC there). So add some transformers, Schottky bridges, big caps and voltage regs like LM10854/5/6 configured as current sources.
That's the theoretical side of it. In practice, the first thing I'd do is buy Morgan Jones "Valve Amplifiers" and read the relevent parts (most of the book!!) three times.
andy
Re: Tube Info
Thanks Cowboy 99 for the links, you're quite right about the SS - Tube learning situation, I feel more confident in the SS side and the Tubes are a bit alien to me. The glow of the bulbs alone intrigues me enough to learn more.
I particularly like these links.
Unfortunately my integrated amp does not have the pre amp out section but instead I think I may try a Headphone amp to dip my foot in the water, I need one anyway. I'm considering doing 1 SS and one in Tubes, I personally think its a good place to start.
Now does anyone know where to find a good source for a design :D
'the tribes'
As long as the differing schools of thought remain towards tubes, tubes will never die out. The 'triodes' have their basis in quality, the 'pentodes' domain is power; the various configurations such as PP, Quad, Ultralinear, SE defined by such things Class A, AB, when A transitions to AB, AB to A............ What fun!
Andy defiantly has point about environment, my quad 60W pentode mono blocks have surely p___ some people off. Their driving 3.5 cu ft thiele-small tuned ports with old class EV T35 & 1823 mid horns (old school efficiency) which has made me seek secluded living quarters; kind of like have a problem-child that society has outcast. ..... defiantly have raised my rent! I'll leave with an email I sent to a friend a few years back...
...should of seen the grin on my face when this Buckethead Audioslave cover just vaporized one of my Sovitek KT88 ballast tubes: Voltage, smoke and glass .... Damn near killed my cat, best laugh in years !!; the window screen didn't even slow her down. Time to align the bias on these 'stacks'. She won't warm herself there anymore.... Cowboy
Cowboy99,
Good post. Maybe tubes will 'die out' or begin to 'mutate' when old stocks fade out and new such becomes unreliable. But as I understand it is mainly the disco/guitar scene that keeps them alive!
(Just a detail correction: The Quad output is UL, not pentode, which is closer to triode than pentode, thus its advantages.)
