Please help me to choose the right toroids for my poweramps.
How can there be as big differens in weight for the same VA ?
Both are 500VA, prim 230V, sek 2x35V, 2x7,14A.
Multicomp from Farnell, partnr:9532552, 4,3 kg.
Nuvoterm from RS, partnr:223-8279, 3,5 kg, (a little bit cheaper).
A differens of 0,8 kg, is it possible and how does that influence performance ?
Which should i go for, which could be the best one, for my purpose ?
I´m going to buy four pieces, so it´s important to do the right choice.
There might be a number of reasons for this difference:
-The heavier one has a more conservative design, more iron and copper.
-The lighter one uses more advanced technologies and materials: high performance magnetic alloy, space-saving winding techniques.
-Both are in fact identical, but have a different design: f.e., some transformers have a cast resin center instead of mounting flanges.
Thanks Elvee
But it´s a weight difference of 20%, nearly 1 kilo, of a pice weighing 4 kg.
It must be some real big difference in performance.
In a power supply for a highwatt amplifier, the transformer has to work in short dynamic swings and one of these must be the right choise.
Hi Ragnwald
The Farnell transformer has a tighter regulation than the RS version, so there is your extra weight.
I would go for the transformer with the tighter regulation as a general rule, but this decision could be heavily influenced by what voltages you want to get out of your power supply circuit etc. Better regulation in the transformer means better regulation on your DC voltages
Cheers
Ray
Cheers
Ray
Hi Rag
Some good information can be found here...
http://sound.westhost.com/xfmr2.htm#11-losses
Look under regulation, but there is plenty more transformer info to get your teeth into, should you be interested
One thing to look out for on your travels, the simple txfrmr regulation definition can be expressed differently. In the USA and other places it is defined as...
(Vnl - Vfl) / Vfl %
where Vnl= no load secondary voltage
and Vfl = full load secondary voltage
Where as in the UK it is defined as...
(Vnl - Vfl) / Vnl %
Hope this helps
Ray
(Vnl - Vfl) / Vfl %
(Vnl - Vfl) / Vnl %
Hope this helps
Ray
Here's a good walkthrough of the process of designing an OT, with some comments on how it relates to a power transformer:-
http://www.geofex.com/Article_Folders/xformer_des/xformer.htm
w
w
- Power Supplies
- Weight differences of transformers
