Hi, restoring an old inca tech amp and need 2 pairs of 2SK414/2SJ119 - wondered if anyone has any before I pay through the nose!
Have tried 2SK1529/2SJ200 as replacements and, without further investigation, am getting distortion in both channels, so would like to track down originals if I can
Cheers
James
Cheers
James
Spev said:Thanks Folks. I'll keep looking for the moment. Housing - are the toshiba fets you have very similar to the Hitachi? I've read threads where amps containing those fets have been mentioned in the same breath as the hitachi ones.
You better check up the data sheets here to see how they are different from each other. Getting the original 2SJ/2SK will surely save you some trouble from bias adjustment .....etc
http://www.datasheets.org.uk/search.php?t=0&q=2sk405&manystr=
http://www.datasheets.org.uk/search.php?t=0&q=2sk414&manystr=
