diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   NCD components (http://www.diyaudio.com/forums/class-d/135520-ncd-components.html)
rootbeer 28th December 2008 05:50 PM
NCD components
I'm in the process of rounding everything up to build an amp out of the newclassd modules. As of right now i'm going to use one transformer and one psu board instead of a duel mono setup (any objections?). Where is a good place to find a transformer and a case? I was also thinking about replacing the included psu caps thoughts?
The amp will eventually power 200watt max towers with a 89db sensitivity.
e_fortier 28th December 2008 10:52 PM
These guys have very good prices, this is where I will order mine once I know for sure which VA rating is required;)
Antek
Regarding cases, if you need rack mount or table top look here;
Par-Metal
Eric
cdl 13th March 2009 07:01 PM
Re: NCD components
Quote:
Originally posted by rootbeer
... newclassd modules. As of right now i'm going to use one transformer and one psu board instead of a duel mono setup (any objections?)
How is your project coming along?
I have speakers that are similar to yours 88dB sensitivity, max 300W.
I built a single transformer + single PSU board setup re-using the case and transformer of my old classAB power amp, and I love it. One PSU is fine (if you want, you can wire one module "inverted" and the other normally; in that way big bass bumps in both speakers will draw off the opposite rails...but I just wired mine up normally, and never found any reason to change it.)
I would stick with the included caps for starters (you could take the 15000F option), you can always change them later if you want They're big enough, mind you... I had to attach mine "lying down" to make them fit in the case. Mine are just the 10000F ones.
Good luck with it.
/cdl
wtfaidh 15th March 2009 03:54 PM
Transformers ?
Transformers ? : http://www.amplimo.nl/
ship all-over
Cheers, Eric.
wtfaidh 15th March 2009 04:09 PM
Casing ?
2 Attachment(s)
I've got a set spare "cases". Only 1 time used, minimalistic design... ;-)
Maybe : http://www.hexateq.com/archived_products.html
some left-overs but very, very nice
Cheers, Eric.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
