PCB advice
I am playing around with the design for my aikido line stage that I want to integrate a phono stage into. I have been weighing between some type of board stuffed guts or point to point for the phono section and still can not decide.
I drew up this little PCB section today...I would do the old copper board - toner transfer technique with this.
Does this board layout look OK? I have never laid out a board before...
The schematic is the RJM 6DJ8 phono stage - with the suggestion of having the tubes run in series instead of parallel - I.E...each tube has a L and R channel instead of a dedicated L tube and R tube...
cjkpkg said:
OK...Here is the latest. I realized that I also needed to run the filaments in series versus parallel...I think I did it right...
Hi Carl,
If I were going to layout a circuit board for this preamp, I would do it in such a way as to not run any traces through two adjacent tube pins. I would also limit it to only one trace going through the 1-9 pin space. Even if you have to use wire jumpers on the top surface to accomplish this. Cramming three lines through the 1-9 opening is not good layout practice in my opinion.
Also, the filament lines should be the widest of them all because they carry the most current. Your's are the thinner of the bunch. Signal lines could be thinner if necessary because they carry virtually no power, although I see no need for that with this simple circuit.
I'll admit that I have no experience with computer aided circuit board design because anything I did years ago was by paper and pencil. But the CAD programs of today should make things much easier. Perhaps give it another try.
Victor
Hi
I would not include the component overlay on the copperside of a valve/tube PCB.
With some of the voltages running on a valve/tube PCB you may just get an arc-over and wham!!! :hot:
But then I am over cautious and a nit picker about things that things that may go wizz-zap-wham and you smell that acrid stink of an electronic part "stepping-over" beyond it's design limits! :smash:
Great looking etched PCB there by the way. What tools process do you use to produce PCB's?
I did the laser jet printout on a transparency. Iron it on and give it a Ferric Chloride bath...
I do plan to coat the solder side after it is stuffed...I have seen some folks recommend using just a clearcoat acrylic. Would this be OK??? Or maybe a clear polyurethane?
Any advice here would be appreciated.
Carl
