Good morning! I've seen in class D amplifiers that eh repaired some are based ICs ordinary as OpAmps and TTLS, someone will have some drawing of this type of amplifiers with these characteristics, because in my country is very difficult to obtain components such as IR2110 or other type of controller of that type. I hope you can help me, greetings ...
The problem is the level shifter for driving the upper Mosfet.
If you don't have access to IC Mosfet drivers, you could try a discrete solution: http://www.diyaudio.com/forums/showthread.php?threadid=82447&perpage=10&pagenumber=1
some other solution here:
http://www.diyaudio.com/forums/show...02125&perpage=25&highlight=lm393&pagenumber=1
Thank you very much, is an excellent solution, unfortunately I could not open the diagrams of the following Link http://www.diyaudio.com/forums/showthread.php?threadid=82447&perpage=10&pagenumber=1, truth, I like to hear other alternatives the IC MosFETs drivers
