What kind of power requirements should I expect for a 5 channel Gainclone (LM3875) delivering 30-40 Watts into an 8 ohm load. Would a 750 VA toroid (24/24 V 15A) do the trick? I assume this should give 150VA per channel which should be just enough.
What would be the best way to wire this kind of setup to reduce crosstalk?
Remember you are talking to a newb here so try to keep it simple
ThanX
ThanX
