According to PE, this can be used with mid/bass at 2-4K Hz, can this be used in BiB with addition of the tweeter? (plan to xover at 2K).
any thoughts?
mid/bass:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-435
tweeter:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=275-035
gychang
any thoughts?
mid/bass:
tweeter:
gychang
There's no reason not to make a two-way bib. I belive that 'Zilla has asked why he hasn't seen any yet.
There are plenty of good drivers out there that aren't "fullrange".
What were the critria for chosing this driver? Any specific design goals?
I was looking at something along the same lines but using this woofer here . It's nearly fullrange so you can bring in the tweeter up high and out of the "telephone band".
Has anyone here made a multi-way Bib?
edit: I got ninja'd on the driver by sreten.
gurley123 said:There's no reason not to make a two-way bib. I belive that 'Zilla has asked why he hasn't seen any yet.
I posted this at the BIB thread before:
http://www.diyaudio.com/forums/showthread.php?postid=1471558#post1471558
I did cross the tweeter ~9kHz to a 5" 'nearly' full range driver.
The drivers I used are not available in the US anymore afaik.
gychang said:According to PE, this can be used with mid/bass at 2-4K Hz, can this be used in BiB with addition of the tweeter? (plan to xover at 2K).
any thoughts?
mid/bass:
tweeter:
gychang
They would make a nice sized BIB. Not real sure about the kevlar cone, some do not like the sound. But, for the price, could be worth a try. As for the little 1.5k spike, dare I say it, a crossover. If so, definetely a little larger tweeter. This may all depend on what the intended use is though.
The driver gurley123 suggested looks very good, have been eyeballng it also. The qts is a bit more in the range for a horn.
Go on Zaphs and look at the specs and graphs of some of the lower end Seas midwoofers. They've got some great flat responses with nice, polite rolloffs up top, ideal for for running fullrange with supertweeters, and many make for only moderately sized BiB cabinets and should be able to handle fairly low tunings, to boot. I'm interested in this sort of arrangement myself, and have run pretty much everything 6" and under through the BiB spreadsheet, just to see, and some of the results were really promising. You're just looking for a reasonable combination of low Qts, low Vas and low Fs (and low $$ in my case, too).
Kensai
Kensai
Scottmoose said:Doesn't really matter as a tweeter is going to be used anyway. The cab. will likely just be a bit larger.
any suggestions on the demensions?, or shall I plug them in on the BIB calculator using the mid/bass driver specs...
gychang
On this Tangband how about an MLTL for it?
I have little experience with Tangband. I got the 871 and was disappointed in the area of efficiency.
The SPL is lower than the FE127e and the Xmax is higher. Vas is similar.
I've been itching to use a 5 in but don't want to invest in
the 6 inchers which would most conservatively be the FF165.
Can someone plug the Tang Band W5-704D 5-1/4" Woofer
into the Martin King prog for MLTL? Where's GM?
gurley123 said:Doh' I remember those now. They had those cool k-slots on them. Have you done anything to them since?
Nothing since really. I'm just enjoying listening music through them these days. They do kickdrums pretty well for their size, more than what I expected to say the least.
zayne742 said:Similar to fred76's units. Very pleased with these. 1 in each of the four corners of the listening/theater room.
Very nice build. That carpet/rug resembles what I have in the listening area.
Where's GM?
Spending most of my quality time dealing with personal stuff I feel I shouldn't have to in a country that claims to have a government 'by the people, for the people' and a justice system that claims you're 'innocent until proven guilty'........
Anyway, TB MLTL where Vb = Vas, Fb = Fs using published specs:
L = 22.75"
CSA = 33.42"^2
zdriver = 8.93"
zport = near/at the bottom
dport = 2"
Lport = 4"
All dims i.d. and approximate. Simmed stuffing density = 0.2 lbs/ft^3 polyfil.
GM
L = 22.75"
CSA = 33.42"^2
zdriver = 8.93"
dport = 2"
Lport = 4"
GM
Thanks so much. This is very tempting. I have something I can use for a mock-up box on hand. But I'm still chary about Tangband and the power they need.
But I have to finish off my Franken-BIB. BIB and MLTL are the only
builds I've ever made pairs of. The trick is to get the clarity of the
MLTL with the depth of the rear horn of the BIB.
Later in the year I may step up to the plate for a Fonken or Mileva.
Lately I have been doing flush mounting of my FE127e's. But elsewhere it was said it's not necessary or productive. What's your take on that?
GM said:It's a waste of time with this driver, though a large felt or appropriately dense open cell foam ring covering the driver up to, and possibly including, the surround and some amount of the baffle to be determined experimentally will in theory be worth the effort.
GM
If I wanted to bring the midrange forward on the bib what is the
best method? Currently there is regular poly fill in the peak, a piece of felt behind the driver. The driver has a 'bonnet' on it around the magnet to cancel reflections. Down in the bottom, there's about
a 1/2 inch of poly.
I have seen the felt ring on some designs.
If the flush mount is a waste, then I can save myself a bundle on
router gear and continue with the smaller tools I have.
We're getting 'thread drift' again. This should be in the bib thread.
Doesn't this driver have a fairly laid back response? If so, I don't know of a way with stuffing since as you increase it to roll off the pipe's gain it's damping the mids down too.
Many inexpensive drivers benefit from recessing, but as I periodically note, it's easy enough to do by just cutting a hole in a separate add on false baffle of a close enough thickness with a hole or jig saw. I didn't own or have access to a router during my prime speaker building years and never felt the need for one.
GM
GM
GM said:Doesn't this driver have a fairly laid back response? If so, I don't know of a way with stuffing since as you increase it to roll off the pipe's gain it's damping the mids down too.
GM
Well the current build is not quite done yet. But the new one has a double baffle as you suggested to cleat the magnet at the rear.
So there's a four inch hole and a five inch hole in the interior baffle board-- no chamfering-- that would have gotten too close to the edge of my 6.75 width.
Far as laid back goes, the mids sound like they laid back in the slant some place.
I don't think a supra baffle would adequately correct for this.
I now have HD radio streams as a source so that might change the
audio balance of things. My source audio equipment is not extremely refined but I think this is a speaker issue, not in some other component.
- Full Range
- in BiB?
