Tom said:
"The only ones I can locate are the real cheep ones that you find in radio shack type stores. "
Actually Tom the Radioshaft pots are surprisingly good. I used them in my 2270 for 6 months until I got a Goldpoint and shoehorned it in.
Had no problem with the RS pot.
"The pot is 50k ohms. marantz part #RM0503061. "
Probably will not find an exact replacement unless someone has one in their stash. The ebay "Blue Alps" clones are also very good surprisingly, I tried these as well and had no problems with them.
I did not like the 23 step pots from ebay. Worked OK for a day and then started to make noise when switched. Cleaning and Deoxit had no effect.
Thanks in advance, tom
Your welcome
Your welcome
