Hi!
I've found a differential-amp output stage topology that uses 12ax7 and 12at7 in a dual cathode-follower configuration that I'd like to try out. Looks like I'll need +230v and -40v and a pair of 12.6v heaters. Any recommendations on a simple solid-state power supply that would perform well in this type of situation?
Thank you!
Thank you!
