diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Cathode stripping in low voltage tubes (http://www.diyaudio.com/forums/tubes-valves/120142-cathode-stripping-low-voltage-tubes.html)
engels 26th March 2008 12:36 PM
How dangerous should it be to apply +6 to +30VDC to a plate of a tube with no heater? Should this cause cathode striping as with high voltages?
I'm talking about spacecharge tubes during the first 11 seconds while it warms up. Is there a need for a standby switch or a timer/relay (with SS rectifier) at all? I wanted to make some field tests but before I'll get to destroying tubes I wanted to hear from someone more experienced than I (which means everybody here).
I guess in worst case it may cause some very minor cathode stripping but if it has no effect than why bother?
pmillett 26th March 2008 04:05 PM
Not an issue.
I don't think that the car radios that used these tubes used a B+ delay circuit...
Pete
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 18.75%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
