What's the best bandpass design calculator
GM
Joined 2003
My knowledge of BB6 pro is limited to dimly recalling some folks posting on the old Basslist of not being very pleased with it overall, but that was a lifetime ago in software years, so can't comment beyond being very pleased with Lspcad's accuracy.
GM
So you've found the accuracy to be pretty much on par for all these programs?
Every program hv it's plus points & negative points.
AJ bandpass is not interactive.
Bassbox pro shows different matching.
But if results from bass box pro fed to winspeakerz, then they r ok.
Winspeakerz gives u 9 different graphs. u select what u like.
Bassbox pro & winspeakerz r auto as well as interactive so that we can design the box as required by us.
Then we can crosscheck with other softwares.
In Subwoofer design tool box u need more experience to design bandpass box.
But the results r almost same within 2~3%.
I visited the website.
The software is a simple one.
S factor is with .1 diffrence. it is high.
The port frequency step is 5 mhz. It is too high.
If u want precise results than u hv to buy commercial version.
No lunch is free.
or else give me the speaker specs with DC resistance, Qts, Vas, Fo/Fs. & ur requirements, all at one time, i will give u the box designed along with graph.
