diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Phono preamp mm (http://www.diyaudio.com/forums/analogue-source/112223-phono-preamp-mm.html)
cartier20002000 20th November 2007 03:19 AM
Phono preamp mm
I would like to make a phono preamp type mm for my turn table. Somebody have something to propose.
cartier20002000:att'n:
Conrad Hoffman 20th November 2007 04:35 AM
You could do a lot worse than the circuit National Semiconductor has in their app note for their new LME opamps.
AMV8 20th November 2007 11:54 AM
Conrad
Thanks for your comment. I just tried to find the application note but could not. Could you give me an op amp number to search against please.
Don
Onvinyl 20th November 2007 12:07 PM
this is it, I think (page2):
http://cache.national.com/ds/LM/LME49710.pdf
Rüdiger
AMV8 20th November 2007 12:12 PM
thanks
Don
woodturner-fran 20th November 2007 02:25 PM
Search in this forum for the VSPS.
excellent phonostage
Thomo 22nd November 2007 07:42 AM
Hi. Has anyone tried the PassLabs Xono or Pearl Phono stages?
Lee.
dangus 27th November 2007 03:08 AM
Check out the Hagerman Technology Bugle preamp kit; those are available on eBay for reasonable prices. Reviews suggest that they perform very well.
http://www.hagtech.com/bugle.html
There's enough info there to build one from scratch if you wanted.
If you listen to house and techno music, you could build a classic DJ mixer phono stage: the schematic for the UREI 1620 can be found online. There's some images online of the 1622 phono card which clearly show the layout.
jcx 27th November 2007 03:17 AM
I strongly recommend against "passive eq" with flat op amp gain stages in RIAA preamps as shown in the national datasheet:
http://www.diyaudio.com/forums/showt...t=#post1014067
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
