Frequency Allocator can now be used inside the Winamp Player thank to Christian Budde's Winamp Allocator Output plugin.
It allows for loading of the Allocator as an output process which makes for a very elegant solution. You set it, close its window and use the Winamp to listen to your music as you would normally, except you have the crossover running in the background.
It's been tested with a few ASIO sound cards and it passed the tests, but as usual, the first release can be a bit buggy, so be cautious.
Here is the link to the announcement:
http://www.thuneau.com/forum/viewtopic.php?t=135
