Where to get transformers for 41hz amp designs?
I'm really not having a lot of luck searching. I was looking at building some of the designs on 41hz.com but the designs that have the power supply built-in require a transformer. I really am not having much luck figuring out where to get one from, how much I should expect to pay, etc. Can someone point me in the right direction? Thanks!
I also used the 160 VA, 22+22 from Parts Express, for an AMP1 kit running in bridge mode. I ran it at clipping into an 8-Ohm load for an hour, without excessive heating. Of course to be safe, you would still want to run your own tests to confirm my result.
