diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Choice: two Trends T-10.1s or one Kingrex T20 w/PSU (http://www.diyaudio.com/forums/class-d/106319-choice-trends-10-1s-kingrex-t20-psu.html)
gnostic19 3rd August 2007 04:44 PM
I am just getting into the Tamp thang...have no idea how they sound(though i have read a bit). I would probably be feeding a QSilver Line stage pre-amp or some passive pre-amp i get down the line. My speakers are curerntly SOund Dynamics RTS-3s.
I am wondering if the dual amping Trends ($260)would sound better than one singularly superior (when compared 1 on 1 with Trends, or so i've read) Kingrex($400) unit. My budget is $3-400 for the amp(s).
I listen mainly to 4-6 piece acoustic jazz, some alt rock and some synthesized beats., but mainly acoustic jazz.
thanks in advance.
preiter 3rd August 2007 07:58 PM
I have no experience with the King Rex, but the reviews I have read seem to indicate that it is marginally better than the Trends, and much of the improvement comes from its power supply.
I would go with the bi-amp Trends configuration, and pick up some inexpensive regulated SMPS (you can get them for under $10) to replace the stock supplies.
As a bonus, you get double the power that way. Not a minor consideration, since we are talking about approximately 6 useful watts into 8 ohms with these amps.
Pano 4th August 2007 06:40 AM
:whazzat: You don't get twice the power with two amps. The amps would have to have a higher voltage output to get more power. It's Ohm's law.
Both are very good, and I think you would be happy with either. The Kingrex has the advantage of a single volume control, if that is important to you. If you have a preamp, then it doesn't matter. The KingRex is somewhat larger and more sturdy, but of course that comes at a price.
Agreed that a power supply upgrade will help the Trends.
gnostic19 4th August 2007 06:47 PM
i asked a dealer who sells both, audiomagnus.com or whatever, and the guy said he would go with the KRex, even when i added the ultra modded to the mix. He also emphasized the better build quality of the KRex.
The concept of dual momo configuration has always appealed to me, even though i have never listened to a dual mono set up. I may have the quality of it blown out of proportion compared to reality.
I will, regardless, be using a pre-amp with the set up...probably a QSilver line stage with 12AX7s.
One other side not...up until my recent disovery of teh T-amp thang, i was going to hunt down another Rotel RB980BX 120wpc amp and do a bridged 2 amp, dual mono design for my system. Only probel mwith this is i won't be able to power my Magnepan MMGs with this, as Rotel is emphatic about using 4 ohm speakers with bridging their amp. Then again, i can't even use one T-amp with the MMGs cause of the underpower issue. I will have to use my RTS-2 SDynamics or a new pair i am researching...either Axiom M22s or JM Labs Chorus 707s.
preiter 4th August 2007 07:57 PM
Oh yeah, this is passive bi-amping. Not really any power improvement at all.
You do get significantly more power from actively crossed bi-amping, though.
http://sound.westhost.com/bi-amp.htm
You definitely don't want to try bridging an amplifier into 4 ohms, unless you are damn sure your amp can handle a 2 ohm load. When bridging, each amplifier sees only half of the load.
gnostic19 4th August 2007 09:32 PM
clarify...
course, i meant that bridging Rotels would not allow me to use 4 ohm speakers. And my speakers are RTS-3s, not 2s.
The thing about having 2 Trends would be the improved imaging, i assume.
dweekie 8th August 2007 05:34 AM
Quote:
What does Panomaniac have to say about this? :eek:
Also, Pano, did you happen to get my email regarding smps?
theAnonymous1 8th August 2007 01:21 PM
Not to **** on the Kingrex , but $400+ for a TA2020........:rolleyes:
I would say either buy the Trends, or if you need more power go for an AudioSource AMP7-T.
bbaker6212 13th August 2007 07:50 AM
Well the cost (and quality) is really in the implementation. As an example look at this even higher-end $1300 implementation of a Tripath amp...which got rave reviews...
http://www.6moons.com/audioreviews/redwine4/30.html
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
