diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Absolute beginner vs Andromeda speakers.. (http://www.diyaudio.com/forums/multi-way/106243-absolute-beginner-vs-andromeda-speakers.html)
Marcopacio 2nd August 2007 08:16 AM
Hello everybody,
I'm Marco from Italy.
Sorry if i bother you with this, but - even though I'm an absolute beginner at DIY - I would like to try, step by step, to build my own pair of Andromeda speakers from a project of Tony Gee.
If I look at his site or even another site with DIY speaker projects, I cannot find any detailed instructions and specifications about the cabinets measurements.
Would you be so kind to give me advice on how to find these info?
Thank you in advance for your kind help.
Marco
Duck-Twacy 2nd August 2007 08:27 AM
Tony always writes: "A higher resolution image is available on request."
So I guess you have to send him an email.
http://www.humblehomemadehifi.com/Contact.html
Will be a problem to get the Focal drivers for this project
Landroval 2nd August 2007 09:05 AM
Yes. I would consider some other projects as the Focal drivers for the Andromeda are almost impossible to find. There are easier and equal quality options available.
Marcopacio 2nd August 2007 10:59 AM
In the meantime I received feedback from Tony with hi-res pic of what I was looking for.
As for the drivers, yes I did a quick search and found out that it's almost impossible to find the very same Focal drivers, therefore here are my options:
A. To replace them with other Focal current production drivers. Even if measurements are the same, I suspect the values will affect in some ways the crossover, therefore I will need some advice on that.
B. To replace them with other brands drivers (e.g. Scan Speak Revelator, others) but this will affect either crossover values and cabinets construction. Insights will absolutely needed in this case as well.
C. To change speaker project. In this case you have to consider:
1. I'm an absolute beginner (as the topic subject mentions..) but 2. I would like to build my statement speakers with no money for Wilson Watt Puppy, therefore DIY.
Would you be so kind to help me in suggesting a very good statement speaker project, whose drivers and parts are still available?
Please don't get bored by my post, even if I'm new, I'm really intrigued by building my own speakers. I would really like to do that.
Thank you.
Marco
sreten 2nd August 2007 12:57 PM
something from any of these :
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
http://www.rjbaudio.com/projects.html
http://www.zaphaudio.com/
:)/sreten.
Landroval 2nd August 2007 01:37 PM
A. I'd say if you can't get the exact same drivers, forget it. Too risky to start an expensive project with unsure results.
B. Yes. That is possible, but definitely not a beginner project. You need experience, measuring equipement and modelling skills to do that.
C. 1. Beginners can build high-end kits if they follow the plans. Usually deviations from the original need a lot of work, but the basic build cabinets, solder the crossover and put it together with the drivers is in the end quite easy (but time consuming of course).
C. 2. Depending on your budget, there are plenty of really good projects available. Tony Gee's coming Project-X should be cool for example.
wigginjs 2nd August 2007 02:45 PM
Check out this webpage:
http://www.edgaraudio.com/
Under loudspeakers there is a speaker that was inspired by the Andromeda using Scan-Speak drivers that I believe are still available.
Marcopacio 2nd August 2007 03:16 PM
Landroval, m0tion,
thank you for your comments, much appreciated.
Yes, www.edgaraudio.com is very interesting.
Is there anything available about the Tony Gee's Project-X already?
Thanks.
Marco
Landroval 2nd August 2007 03:30 PM
[B]Is there anything available about the Tony Gee's Project-X already?/B]
There's photo on his news site. Basically it looks like the Mårten Design Coltrane ($50 000/pair), but Tony seems to be using the bigger/better T&P C90-T6 midrange instead of the C79-6 (?) in the original Coltrane. Also I believe he's using a ceramic tweeter (C13-6 or C24-6 probably) instead of the ridiculously priced D20-6.
ermes 2nd August 2007 03:42 PM
marcopacio,
before you follow the way of diy,you must know your musical taste to choice the sound you prefer.
b.r.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
