got Panasonic Metal FA-3459 8"
qts seems much higher than posted tech-spec from Panasonic and could be guessed as possibility as seller saying it works well in TQWT
assuming didn't botch T-S what's cool for good compromises with this type driver?
when watching it play without a box, I advanced volume slowly on a track with bass and cone didn't move much further - it mainly went into compression and more modulation rather than increase of peak movement
by "metal" - is its wizzer aluminum?
in a 3.2M BIB sim below, 1mm is reached at 0.65 watts ~52Hz
60 inches height is pretty far from my 7'10" ceiling - how are these type inverted?
seller's pix
cone
http://img74.imageshack.us/img74/4149/con1gk9.jpg
rear
http://img165.imageshack.us/img165/6513/fram1wg7.jpg
Simulation 3.2M 182 liter BIB
http://img481.imageshack.us/img481/3292/32mbibvs35lbrht1.gif
Unit #1
Revc = 5.4657 ohms
Fms = 58.1931 Hz
Zmax = 52.8627 ohms
Qes = 0.5830
Qms = 5.0553
Qts = 0.5227
Le = 0.2559 mH (at 1 kHz)
Diam = 161.9504 mm ( 6.3760 in )
Sd =20599.3690 mm^2( 31.9291 in^2)
Vas = 33.9940 L ( 1.2005 ft^3)
BL = 6.7431 N/A
Mms = 13.2638 g
Cms = 563.9369 uM/N
Kms = 1773.2482 N/M
Rms = 0.9593 R mechanical
Efficiency = 1.0798 %
Sensitivity= 92.3513 dB @1W/1m
Sensitivity= 94.0057 dB @2.83Vrms/1m
seller's pix
cone
rear
Unit #1
Revc = 5.4657 ohms
Fms = 58.1931 Hz
Zmax = 52.8627 ohms
Qes = 0.5830
Qms = 5.0553
Qts = 0.5227
BL = 6.7431 N/A
Mms = 13.2638 g
Cms = 563.9369 uM/N
Kms = 1773.2482 N/M
Hi Eduardo - - - I meausured the parameters as above but have not thought of a good enclosure - - - by qes it would be suitable for MLTL/reflex but may play in certain blh to remove the baffle step - - the only blh I have is BK20/201 and I might test and listen.
it could go on open baffle with a woofer.
wonder what enclosures various buyers have liked (?)
this Panasonic isn't as extended on top as Nirvana 10 but its sweet- - here's an inroom plot on-axis vs a Sammi 8"
http://img222.imageshack.us/img222/2950/panavssammion1sz0.gif
Best,
Freddy
Best,
Freddy
Panasonic Metal-FA 3459
Hi Freddy,
I recently picked up a pair of these Panasonic Metal-FA's and was wondering if you had any success with them in the BK20 or open baffle enclosures?
Thanks,
Greg
Hi Freddy,
Thanks,
Greg
Best,
Freddy
How much is this panasonic driver and where can you buy it in the usa?
I recently bought a panasonic hair buzzer and love it!
Godzilla
Soon after bought one pair of them, I saw your this thread
Last one pair drivers wait for you, Links below
Panasonic 8 inch Fullrange Full Range Speaker - eBay (item 270480463975 end time Dec-04-09 18:56:34 PST)
- Full Range
- What's a good enclosure for Panasonic Metal FA-3459 8"?
