diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Tube rectifier to Solid state Diodes exchange (http://www.diyaudio.com/forums/tubes-valves/105556-tube-rectifier-solid-diodes-exchange.html)
finwbu 20th July 2007 05:20 AM
2 Attachment(s)
The rectification of my Tube tester want to be modified with solid state Diodes like 1N4007, which will last the life of the tester, and avoids the heat produced by the type '83' mercury rectifier valve, which aids both stability and reliability.
Can some body check or made correction on my drawing ???
Cheers Walter
finwbu 20th July 2007 05:21 AM
2 Attachment(s)
Like this ??? wrong or write:)
Colt45 20th July 2007 05:41 AM
sure. It will ride about 15v high though.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
