Hi all,
I have recently started reviewing a number of my projects and adding 100ohm or 10ohm anode stoppers. This has been particularly effective with my RH807 amp, my Thorstens phono preamp and with a 5687 preamp. In all cases it has taken a slight edge off the top end and in the case of the 5687 preamp it helped remove a hum issue.
All these instances have involved flying leads to the load resistor or to a CCS.
What do other people feel about the need for anode stoppers ?
Everyone talks about Grid stoppers, but few people seem to use anode stoppers.
Shoog
Shoog
Shoog said:Hi all,
Shoog
ferrite beads are helpful on all toob pins
in some cases they aren't enough ,so you must use resistors instead
Sorry for a stupid question, what is anode stopper? How is used?
When the load on the anode isn't right up on the valve base(ie in the case of a CCS or a heatsinked load resistor) - you add a small resistor onto that base at the pin.
This helps prevent the valve from going into radio frequency oscillation, which inevitably leads to intermodulation distortion and other unpredictable results.
Shoog
