diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Basic question on 6922 (http://www.diyaudio.com/forums/tubes-valves/10052-basic-question-6922-a.html)
ghee0 18th January 2003 09:58 AM
I am new to vacuum tube, just wondering what is the purpose for Pin#9 on 6922? Is it a shield? When should i apply or use it?
Thanks.
ghee.
fdegrove 18th January 2003 11:07 AM
6922
On this tube pin 9 is a shield indeed.
It should be grounded.
Cheers,;)
apassgear 24th January 2003 03:53 PM
To ground or not to ground
Even if you use the the tube in parallel? (the 2 sections)
fdegrove 24th January 2003 03:55 PM
Re:To ground or not to ground
Yes.
Cheers,;)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
