At Pc Power Supply Conversion??. - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th March 2007, 08:51 AM   #1
Marvellous's Avatar
Question At Pc Power Supply Conversion??.
Hi
I'd Like to know if it is possible to Convert a old Pc Powersupply
to a +-35v Supply?...
I was thinking of Rewinding the Secondary
& repacing the Caps & Filter
But dont know how 1 wld go about with the feed back
Dose anybody have plans on doing that?
or Else does Some1 outthere have a schemetic
of building 1 from scratch?
I'm Very interested in SMPS at the moment
Thanks in advance
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minuteóand itís longer than any hour. Thatís relativity." - Albert E
Old 13th March 2007, 04:32 PM   #2
N-Channel's Avatar
Send a message via AIM to N-Channel
Did you search?
There are several threads in the Power Supply Design forum on converting old AT & ATX powerboxes: Some from the +/-5V & +/-12V to +13.8V, Some to (+/-) Medium Voltage (for Audio Use), and others for converting to 12V input, etc.
As far as converting the secondary side to do this, sure, it's possible, depending on the model of the PSU (there are literally thousands), how the board is layed out, and of there is a space on the +12V line for a filtercap after the BIG yellow Toroid, but before the output filter choke. Most AT & ATX skip this.
Also, these mods work best for half-bridge units (easily identifiable by a TL494 on the secondary side, and two transistors on the primary side). If you encounter an 8-pin dip UC3842, '43, '44, or '45 PWM chip on the primary side driving a single hiogh-voltage transistor, then you have a flyback unit, and then things are somewhat more complicated.
Hope this helps..
Steve
Old 14th March 2007, 12:32 PM   #3
ifrythings's Avatar
I would use a PSU that has a half bridge design as N-Channel stated, it's a lot simpler to work with.
Also you should try to find a PSU with the largest transformer in it, it makes winding easy and gives you lots of room for extra windings (wich is what you need).
Here's a schematic of one too (you'll have to remove the over/under voltage protection on the left but other than that it's reletivly simple.)
P.S this is not my schematic it belongs to the original author.
Edit: typo's
Old 15th March 2007, 02:50 PM   #4
Marvellous's Avatar
Thanx for the reply the 1 I have is like the 1 on the above schemetic (except 4 the component numbering)
also using a tl494 & transistors
Does any1 have a Idea how to modify the feedback
for 35v?
wold replacing the trans former with a E39 have any bad effects
(i wld rewind the primary with same no of turns as the original one)
Thankx again will keep u posted on my results
Old 15th March 2007, 11:04 PM   #5
jkeny is offline jkeny  Ireland
Banned
I posted on this a little ways back modyfing a pc switchmode for B+
Although this is about changing AT supply to higher V+ levels I'm sure it can be adjusted for 35V+.
You'll find the article in here: http://rapidshare.com/files/12323786/siliconic.rar.html
John
CELLO Duet 350 supply conversion alex66 Solid State 1 7th November 2012 02:48 PM
ok, power supply question, 230v - 117v conversion aardvarkash10 Tubes / Valves 6 21st July 2009 01:11 PM
Harman Kardon HD7600II power supply voltage conversion runethechamp Digital Source 1 26th May 2009 07:00 PM
External 12V heater supply conversion question luvdunhill Tubes / Valves 20 18th February 2008 06:33 PM
Copyright ©1999-2017 diyAudio
